If it has that sticker, its basically approved to run on any petrol/ethanol based fuel.The fuel door doesn’t say, I’ll have to check the manual.
The LFX engine wasn't built to run on 91, the compression ratio is way too high. Knock sensors pulling ignition timing out enables them to run on 91 but not at maximum efficiency. There're a few spots where the knock sensors pull timing out on 98 and that's on the cusp of sufficient octane.91 is fine and what they were built to run on.
5-30 oil in the sump changed often.
Yet with the LFX as used in the USofA, GM specs regular petrol which is 87 ((RON+MON)/2)The LFX engine wasn't built to run on 91, the compression ratio is way too high. Knock sensors pulling ignition timing out enables them to run on 91 but not at maximum efficiency. There're a few spots where the knock sensors pull timing out on 98 and that's on the cusp of sufficient octane.
The correct fuel for any engine is determined by the detonation resistance at the ignition advance producing maximum torque. GM are relying on knock sensors to reduce ignition timing and prevent detonation using a lower octane fuel. The LFX engine at a compression ratio of 11.5:1 would need at least 100 octane fuel as they detonate on 98 between 4750 and 5300 rpm. Manufacturer fuel recommendations take cost into account like extended oil change intervals for the perception of being cheaper to run and maintain, but it's not necessarily ideal for the engine.Yet with the LFX as used in the USofA, GM specs regular petrol which is 87 ((RON+MON)/2)
Using 91 may not be the most efficient performance wise but it’s not hugely less in the amount of kms per tank verses 98 so it’s somewhat cheaper to run with… and according to GM it supposedly causes no long term damage to the engine doing so
