J_D 2.0
- Mar 20, 2020
- 2,965
- 6,996
- 113
- Location
- Ipswich
- 2009 VE SSV M6 on LPG and 2022 Kawasaki Z650L
Interesting. So that’s probably the case with a lot of modern cars. IIRC in the past it was difficult to get above 10:1 compression without causing detonation.The correct fuel for any engine is determined by the detonation resistance at the ignition advance producing maximum torque. GM are relying on knock sensors to reduce ignition timing and prevent detonation using a lower octane fuel. The LFX engine at a compression ratio of 11.5:1 would need at least 100 octane fuel as they detonate on 98 between 4750 and 5300 rpm. Manufacturer fuel recommendations take cost into account like extended oil change intervals for the perception of being cheaper to run and maintain, but it's not necessarily ideal for the engine.
Modern high compression engines that are well above 10:1 are probably all relying on pulling timing out to run 91 octane, which sort of begs the question why some manufacturers insist on 95 octane fuel when they could just pull some timing out and allow their engines to run on any fuel?
Might be more to do with the higher sulphur content of our 91 octane which isn’t allowed in most other markets. Specifying 95 octane allows them to run the same fuel system as US and Euro markets without adjusting anything for our high sulphur fuel?
