Djayz
- Aug 30, 2015
- 1
- 0
- 0
- Location
- Brisbane
- VX EXECUTIVE V6
Hey Guys,
As I often use this forum to get answers about my commodore, I registered today to ask you a few questions about my personal case, as it's very specific and tricky,
I have a holden commodore V6 VX Executive, 2001, that I bought a few months ago around 200 000kms.
I drove more than 20,000 with it, but troubles started about 5,000 kms ago.
Temperature needle rocketed for no reason in the middle of nowhere, and then all normal, from time to time temperature was rocketing. Went to a mechanical, told me everything was fine, that i had to go to an electrical mechanical.
He changed my relays, that were full of aunts, blocking the fans to work properly. Meaning, I drove like 2,000kms with fans not working properly, that's why sometimes temperature was rocketing, fans didn't do their job.
Then, I drove 2,000kms without problems, but I drove up a hill, needle rocketed again, went to a mechanical, compression issue with the head gasket, there is a leak somewhere, it would cost me from 1,5 to 2ks.
I bought the car for this price or so, and I will drop it to a wreck when I leave Australia, as I don't want to sell it if it's not working properly, not my type.
I chose not to go for the head gasket changing, and went to another mechanical who changed my thermostat.
Since then, no problem, temperature very good and car going ok, no white smoke, no bubbles, no milky oil.
Drove maybe 1000kms, but now my coolant is getting quickly low, moreover coolant from overflow doesn't go in my radiator anymore, I have to fill in directly the radiator by opening the radiator cap.
More important, a significant amount of coolant is visible on my oil cap, meaning that the leak is now bigger than before.
My question is, as I still have 20 days of travel to go, and about 1100 kms, do you think the car will be able to make it or do you it will die before that ? Visible milky oil started 100kms ago.
Do you think i should use Aluma-seal, or is that worse than good ? Considering that the car is going to wreck anyway...
Cheers!
Jason
Cheers!
Jason
