Holden get their local lock smiths to do the keys, that's why they jack the price up... The locksmiths do it for around $80-$100 and then Holden up the price... My mums a locksmith and this is what happens at her work. Cut Holden out and go straight to a locksmith. It's exactly the same product
Change them yourself !!! Very easy and cheap, under $4.00 infact !
1. Order battery CR2032FH2 (Has solder tabs already installed) from batteriesdirect.com.au
2. carefully pry open case along seam, i use a razor blade or similar fine edge tool.
3. have camera ready and take notes and pics of placement of seal, contact probe, battery polarity exactly how it comes apart (there is a up side to the seal also!)
4. note where solder tabs protude through circuit board, De-solder those tabs only and remove battery.
5. fit new battery (remember polarity + -)... solder in place and re-assemble in reverse order ! Way toooooooo easy hey
6. Carefully glue case together (Dont use superglue !!! PVA wood glue works best "Exterior") clamp case and leave overnight And yes... i said PVA wood glue !
You do require a fine tip soldering iron, vacume desolder or solder braid... JayCar, Tandy etc have these and will give you basic tips on there use
Good for 10-15 years again
