[VE] How to: LLT to LFX engine swap
brenny_90
Byron Bay
VS Ute
A better way to ask my question..my ve is series 1 LLT, someone up in the thread said the electrics/modules differ from series 1 to 2, so even though mine is series 1 could I pull this swap off without having to mess around with recoding modules/ecu. ie: has someone done this swap with a s1 LLT?
Cheers.
GB40
VZ
Hi All,
Prob should have posted here. Looking for a knackered LLT to rebuild....rebuildable. Prefer if it still has the accesessories and sensors. Engine loom could be handy but not essential. No need for the ECU, etc. Ideally somewhere close to Adelaide if possible...... TIA
brenny_90
Byron Bay
VS Ute
Has anyone that's taken on this swap run into an issue after swapping the LLT injectors/rails onto the LFX, with the fuel pressure sensor fouling on the bottom of the intake manifold, making it impossible to bolt the intake back on?
blkvewgn
New Zealand
VE Wagon
My brother and I recently completed a successful LLT to LFX engine swap for my 2009 SIDI VE SV6 ute and figured it would be beneficial to share the process for anyone else who is thinking of doing the same. The whole swap was completed for just the price of the LFX + cats, with no tuning or reprogramming required. All up the swap took my brother and I about 24 hours spread over 4 afternoons, but you could probably smash it out in 1 weekend.
So why would you choose to do this in the first place? I’m sure anyone with a shagged LLT engine could tell you just how hard to find and expensive a fresh LLT is, costing about 25-50% more than a similar LFX. The LFX is much more common, being in all SV6s since the VE Series II, so you’re more likely to find a newer, low km engine for cheaper. The LFX is essentially a new and improved version of the LLT, with integrated exhaust ports, a lightweight redesigned intake manifold, Fuel Flex (E85) capability and a slightly higher compression ratio. But because of these differences it isn’t a direct swap with the LLT. It runs a different ECU, different fuel pump and injectors and slightly different wiring harness. Because of this most people will tell you it’s not worth doing because it will be too hard or expensive once you find the right parts and software to make everything work. But my brother and I worked out a much simpler process which is comparable to a direct drop in swap.
The only things I had to buy to complete the swap was an LFX engine (which came out of a 2016 VF SV6) and the catalytic converters/header pipes to match. All other parts and electronics came directly off my original LLT engine. I also had access to a car hoist, transmission jack and a forklift to remove and install the engine.
To start with you will have to remove the bonnet, and removing your front bumper and headlights will also allow better access to the engine bay, but isn’t 100% necessary. Next, drain your coolant, oil, power steering fluid and clutch fluid. Then you need to disconnect everything connecting the engine to the car. We removed the engine by first dropping the transmission with the jack, then lifting the engine out separately with the forklift. We didn’t remove the radiator to save having to recharge the AC later, but the whole front end can be removed to allow the engine and transmission to come out through the front if needed.
Once the engine is out, remove the wiring harness from both engines, making sure to take note of where it all plugs in. Next, install the LLT wiring harness on the LFX. This is fairly straightforward as the plugs are all identical between the two motors except for a few differences. The water temp sensor on the passenger side is further back and down on the LFX, but plugs in fine. There is also an extra sensor on top of the intake manifold which is not present on the LLT, so we just left this unplugged.
Then you will have to swap the sump from the LLT as the oil level sensor is in a different position and has a different plug. This can be tricky because the bolts on the front of the sump are blocked by the harmonic balancer, so this will need to be removed first to give you clearance. You will likely need to buy a tool for this. Once the sump is swapped you will also have to swap the engine mounts because the LFX ones bolt into the sump while the LLT ones don’t.
Other parts you may have to swap over depending on what came with your LFX engine are the alternator, starter motor, clutch, power steering pump, vacuum pump, and AC compressor. The LFX I had didn’t come with any of these, but if yours does they should be fine as long as they are in the same position and the plugs are the same. Otherwise just swap them all over from your LLT.
The LFX from the VF doesn’t have a power steering pump because the VF has electronic steering (maybe the VE II as well I’m not sure), so that will need to be swapped from your LLT. You will of course also have to swap the power steering pump mount.
The mount for the AC compressor on the LFX is also slightly different, so it will need to be swapped as well or the compressor will sit too close to the power steering pump for the drive belt to pass.
Lastly is the fuel system, including the fuel pump and injector assembly. The LFX is Fuel Flex capable, meaning it can run on E85, while the LLT is not. This means the injectors on the LFX are bigger. I’ve heard it is possible to run the engine without swapping these but the car will need to be tuned to accomodate. We made the mistake of not swapping the injectors initially and the car ran way too rich, backfiring heaps and throwing engine codes. It will not run properly without either tuning the car or swapping the pump and injectors.
Swapping the fuel pump is straightforward, but the injectors can be a bit more of a hassle. The injectors on the LLT aren’t designed to be removed with the heads on. They just barely don’t have enough clearance. So to get them out you will either have to remove the heads first, which is a big job, or do like I did and use a die grinder to shave a few mm off the back of the water outlet pipe. Then you should be able to wriggle the injectors free. The LFX injectors come out much easier but will still take some wriggling.
Now you’re ready to install the LLT injectors. Make sure to give them a good clean or even take this opportunity to replace them if necessary. I found it much easier to install the injectors and wiring first, then dab a small bit of silicone grease on the top seals to help the rails pop on afterward. Then just connect everything up and you’re good to go.
Once you’ve done all of this it’s a simple matter of reinstalling the engine the same way you took it out. We chose not to install the new cats until after the engine was back in to give us more room, but it can be hard to access the bolts once it’s in, so do whatever you find easiest there.
Once the engine and transmission is in everything will connect straight back up as it was before. The cats will bolt straight up to your original catback exhaust as well.
Once everything is reinstalled, make sure to replace any fluids you drained and bleed your clutch and power steering if needed.
Finally, start the car. It should almost start straight up and shouldn’t throw any engine codes. When I started mine up first it did throw an engine code, but a quick look with the scan tube showed a faulty cam position sensor from when the engine tipped over during travel, so we swapped that out and had no more engine codes.
I’ve since driven several hundred km with no issues. Power feels good, fuel economy is good, runs very smooth. I’d definitely recommend doing this swap if your LLT engine is shagged and you have the means of removing an engine in the first place.
Hi,
I am about to undertake this conversion myself as my LLT VE Wagon needs a replacement engine. Did you use the LFX intake, plenum and all the associated vacuum hoses? What about the throttle body? did you use the LFX or LTT one?
Thanks
Ozziman
51
Nsw
Ve 09llt-13lfx
Thankyou for your help,i just finished the swap from llt to lfx and all the info that you posted got me through the changeover.
Thankyou.
  • Like
Reactions: Lex
gcmc
68
Bathurst
Ve 2 Ute
Hi, can you tell me why the cats need to be changed with this conversion ? I'm about to do the same conversion. Have the LFX with all accessories included but want to do it like you did keeping the LLT ecu etc. May consider leaving the LFX injectors in if the programming isn't too expensive. cheers
Fu Manchu
WA.
I’m pretty sure it’s for environmental reasons. If you want the car insurable and registered the emissions would need to be updated too. Was it Euro6?
Or it’s because there is no manifold and the cats are part of the first section coming out of the heads. Or maybe LLT was like that too?
gcmc
68
Bathurst
Ve 2 Ute
I’s because there is no manifold and the cats are part of the first section coming out of the heads. Or maybe LLT was like that too?
Thanks. I see the reason now is that the cats are on the exhaust manifolds. I'm relieved to find out that the VF manifolds with the integral cats bolt on to the exhaust system right where the early cats do. I'm told by a Commodore wrecker that the LLT and LFT engine even bolt to the LY7 Leo type utes. So the cat back exhausts are the same in all VE / VF V6 models.
gcmc
68
Bathurst
Ve 2 Ute
Thankyou.
I'm just about to do the same swap of LFX into my LLT ute. I saw someone talking about problems with fuel lines. Did you encounter any ?
Fu Manchu
WA.
Correct
