Moreys oil stabalizer.
Wayne001
61
Meadow springs
Vf calais
Tried up loading a video but even a 15 second one is to large .
Immortality
Staff member
Sth Auck, NZ
Put it on youtube or another video hosting site and then link it here.
Brown Dog
2017 Nitrate Manual Redline
As I said if you dissagree thats fine. But I'll wager the OP comes back and tells us one of his lifters is borked. Yes it's impossible to diagnose on the internet but it's the same as I see a CMP correlation code on a V6 I know it's chains like I know lifter noise on a 6.0l is a shaged roller due to skating.
Shane, you probably know your stuff, but work on the delivery of the message and you wont get so many off-side. It is the internet after all
EYY
VS Statesman
It is interesting this roller follower skating fault, is it a GM problem or a general roller cam fault? I only ask as it's not a fault mentioned on the forum before and we see questions about all the common fault.
X2 never heard of it being an issue.
EYY
VS Statesman
Some of that sounds like injector noise and some almost like pulley/belt noise.
Does it change when a/c etc is on at all?
Imo doesn’t sound too sinister but again very hard to tell from a vid
1985VK
Australia
VK SL
Squirt some water on your belts and see if it affects the noise
Wayne001
61
Meadow springs
Vf calais
Defiantly coming from the rocker gear on drivers side . Have eliminated all the other noises .
