RSTEP
- Oct 13, 2014
- 16
- 0
- 0
- Location
- Melbourne
- VY 2002 Stock
Hi all interested forum members.
Just before i get started I have read through lots of info about my VY berlina both on here and online.
The community support from this forum is by far the best by far so thanks everyone.
I decided against creating a large post re all my issues and what i will be doing, in favor of shorter more specific threads.
I tend to be quite specific and pedantic with details with what i am trying to do and my approach is if it has to come off the car while doing something else you might as well service it as well.
After having an absolute CRUDDY and disgusting not to mention complete waste of time, money, experience and an absolute destruction of my trust for my mechanic and liability i have over the months begun to learn more about my car and become more informed as not to get ripped of for the 5th or n'th time
Not to mention actually ensure the safety of myself and family.
Righto
The patient:
Holden Commodore VY Berlina 2002
Regularly serviced at all service intervals.
117K Km's on the clock
Received from my late father at 80k Km's on the clock
Fitted LPG at 100k Km's
The problem:
For the last few months the car has somewhat frequently started roughly on either Petrol or LPG and only ever after being left off for extended periods of time, 12 hours or so / over night. it does not matter whether its a cold or warm day.
The idle is not stable and is considerably lower then when i originally got it. RPM just over 600 and wavers.
The Bloody car shakes like it has the shivers.
On occasion its really bad and stalls especially when you try rev it just a little (My experience shows this really does not work, and stalls with a clunch! only once though)
Normal idle when working fine 750 to 800
The Workaround
Not to rev it out
Turn off the car and turn it back on and all is good revs' go back to normal.
Remove the battery and charge it slowly for a day or so (THIS REALLY MAD A DIFFERENCE)
beforehand the battery would only reach 13.7 V when car was idling, after the trickle charge its happily sitting at 14.1V 14.2 V at idle weeks after the charge
The battery is a standard, getting on in its age battery 2542 at CCA 555 RC 95. I had it tested and was sitting at 470 CCA, So still workable. will need to consider a change at some point. Not sure about the required CCA for the VY though.
My approach to fix the problem and Questions
If any other member could offer advice/experience and or additions to what i list below and or answers to questions that would be Great.
As mentioned above I have checked, charged, and conditioned my battery terminals and connectors which has made a nice improvement however i would like to do the following.
To address this i have found that it can be a number of issues related to the Air intake system and ignition so i will be removing and cleaning and these parts
The air box.
Air snorkel
MAF. (Clean with dedicated MAF solvent spray)
Throttle body (Clean with throttle body cleaner)
Air Filter (Inspect, clean or replace)
Spark plugs (check Gaps, resistances, insulation faults and cracks)
Spark plug leads and Boots (Clean, Check condition and resistance, look for deposits, use of electrical contact cleaner and solvents)
Starter Coils (Not Sure about these yet)
All fuses / relays (test and contact clean)
Clean inside the plenum.
Using a fuel additive to clean the fuel system. (Ill take before and after images of carbon buildup and breakdown)
Others:
Belts and tensioners
Questions if people can help me
1:The Throttle body. I have been unable to definitively confirm if i can use my throttle body cleaner on this part. I cant seem to determine if my throttle body has a lacquer coating that would be removed by the cleaner. Can anyone confirm that i can clean this part and that it does not have a lacquer coating.
2: Spark Plugs. They should have been changed many times by name but is there a way to check if they are indeed still the stock plugs. I think ford puts coloured dots on theirs to identify OEM parts for warranty purposes, Does Holden do the same for stock parts?
3: Spark Plug leads and starter coils. Can someone shed some light how to properly remove these parts either by recommended procedure or common practice?
4: Any suggestions on what i can use to block the bottom of the plenum chamber whilst i clean it with the throttle body cleaner? any better way or should it be removed entirely?
5: I have had a look at my air intake Box where the air filter sits, to me it does not look like it is sitting correctly and that the box has deformed. Does anyone have a pic they can share of a stock box and filter so i can compare and decide whether or not to replace my air box.
Any help you can offer or additions to the list above would greatly be appreciated.
RSTEP
Righto
The patient:
The problem:
The Workaround
Not to rev it out
The air box.
Air snorkel
Others:
RSTEP
