Hi all
Just to clarify …the car has been parked for the majority of time since it was serviced ….I sent them a text message mentioning the gearbox amongst other issues after the service …I have supplied the photo of the receipt .
The car was driving ok …only was hard to get moving from park …and there was Tranmission oil leaks where it stopped each time .
It started to get worse ..so when I took it to mechanic …at Robinajust to see if it was just a leak that could be rectified …he tightened up the bolts …the car went great for a day …then went back to bad.
It then on a recent cold day spurted oil from the filler tube and smoke is coming out of engine bay …even after I wiped engine .
It refuses to move more than a few feet ..and then makes a clunking noise .
I am broke a casual worker who has just had his hours slashed ..I would like to sell the car as is for $3500
The engine sounds great ..it has minimal rust …Approx 150000 km .
It is a red Executive station wagon
Tyres have done approx 5000 km since replaced with new ones.
Engine oil replaced …front and rear brakes done ..not many km ago.
The car is honest …the gearbox was fine until Autobahn serviced it …and that is the honest to God truth.
Its no use fighting them ..I just want to sell the car and use the money to buy another car.
Obviously a car yard will give me nothing if I can’t even drive it to them.
I have seen the same model car in the same red restored to as new …they look stunning witha respray and mag wheels .
I believe this car with some work and a respray will be worth decent money in approx 5 yrs .
cheers.
Holden VY commodore 2003, red wagon Executive approx 150000km
Do as has been suggested by above. Completely drain transmission and empty pan, refill with specified trans fluid, make sure pan is bolted up to torque specs.
If you aren’t capable, do your research and get a reputable transmission company to do it for you and explain that they need to do this properly unlike the last company.
The way I see it, you’ve got nothing to lose at this point. Even if you sell the car as is for three grand it’s not much to put towards another second hand car that may well be in worse condition than your VY.
And one would imagine if you are battling for a quid now, you could well end up in a deeper well of shite if you make the wrong decision.
