style dials
stevegunn
eltham nth
vt acclaim wagon vt acclaim sedan
installed style dials now gauges problem
Hi all, I've replaced my vt dash with style dials however now for some weird reason the temp and fuel gauges wont move!? :ranting:
All I did was take the needles off then put 'em back on.
Yes it has fuel in it!:thumbsup:
Anyone come across this before?
Whats the go to get them working again?
Steve
wrx884
WA's ASR Rep
39
VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
yer id say uve pushed the needles in 2 hard they dont need ne pressure at all wen puttin them back on.
accentstencil
71
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
wrx884
WA's ASR Rep
39
Nope, checked that, they move freely;)
yer they will still move freely still but they might b in 2 hard 4 the lil mechinism 2 work u need 2 test em in ur car wen u put em on and then turn ur car on n see how they go then
deserthead
Cairns QLD
VS III l67 Column Shift Ute
Yeh I did the same thing, u have pushed em on too hard.
Just get a fork under them and lift them a little and u should b right.
stevegunn
eltham nth
Done that as well, theyre almost falling off!!
I'll keep mucking:thumbsup:
stevegunn
eltham nth
Well I think i've tried everything now, plugged in, mask off, had the needles only just on then a little more, still no go:bang:
I'm wondering if the shaft of the needle is rubbing on the hole just enough to stop it working? Doesnt feel like it though.
Does anyone know if they should "fall" back down the same as the speedo and tacho do. The fuel and temp just stay where they are when ya move them.
Steve :ranting:
wrx884
WA's ASR Rep
39
sounds like u may have damaged them the 1st time u put em on or were they like that in the 1st place?? they r ment 2 drop 2 the bottom like the speedo and revs as u said prolly trip 2 the wreckers get a stuffed cluster and replace the mechinisms that rnt working might b the cheaper way 2 go then buyin those bits seperate from holden
deserthead
Cairns QLD
What about trying it all again?
Start from scratch, try and align the facia better(????) and the gently put the needles back on.
With mine, I put the needles back on all the way, then used the fork to get them off, quickly. (Does that make sense?) Dont pull em up slow, do it fast, it might pop the shafts back to where they're meant to be.
Did on my one. . . . . .
