Lex
- Sep 19, 2012
- 5,886
- 5,245
- 113
- Location
- Geelong Victoria
- VT Executive S1 V6 6 speed Auto Wagon
Have you scanned the abs/tc. Or just shorted the pins on the dlc? I think pins 5 & 12? @BlackVXGTS I think you know the answer to this?Ah that makes more sense. I don’t think it could be in the tune since I changed the ecu and the whole loom. The ecu is from a dual fuel VX Acclaim but I’m not sure what the wiring is from. Is there anything else you would have to do to get the trac off function to work? Thanks mate
The cluster has to setup for the careg. How many airbags v8 v6 exec. berlina calais. This for different stuff for the different models.
I use @envyouscustoms body diagnostics for setting up clusters. It has more features than a lot of scan tools.
You need the ALDL cable & software. Unfortunately you only get to lease the software for a 30 days or 1 year. Check it out.
Its possible the cluster has already been setup for the car. Maybe not, when you got the car, it had the v8? Now it's got the v6.
But then again you can get different versions of the abs/tc modules, you may have the wrong one?
Scan it first, see what comes up?
My vt wagon has a vx abs/tc in it from a vx sedan. To get it working l to get a passenger rear brake line from a vy wagon calais front hubs from a vt. My cluster was already configered for the abs/tc.
Hope this helps?
