torana355
- Mar 24, 2009
- 889
- 3
- 16
- Location
- Sydney
- VE SERIES 2 MY11 SSV A6 in IVY GREEN
Mate I realise the shop is good and had a few friends go there too, one spent over $30,000 modding his HSV Tourer Black Edition through that shop. But I think it has relatively conservative approach and typical value for money / results. Sure the shop is experienced but I suppose the fine point is it is not an engine builder per sé, more tuners and installers for outsourced engineering. Each to their own, I prefer more cutting-edge experience with the new race technology and direct dialogue with engineers in the detail versus outsourced brands / what's worked in the past.
Yes the L77 responds well to a longer stroke but not with a small cam, crank and rods extra $2500, but while it's cracked and you are honing anyways you might as well take it out a bit to 370ci. I agree those pistons look ####ing amazing in the web video too. When the heads are off for overhaul consider LS3 valves and quality beehives. Then the pistons, bore and 0.040" off the heads will definitely bring it into hi-comp ethanol territory, I'd aim for 13:1. Cam, heads, compression should get a 370 well into the 340's at the rear, on e85 will boost cylinder pressures about 33% to add at least 15% performance on top of that, run better, and use 20% less (cheap) alcohol.
PS You can do better for a couple grand less :yarr:
The cost was a very rough ballpark. I have an engineer mate who is keen to rebuild the motor for me as well and he is much like you, he would want to make his own custom grind camshaft ect ect but Sam specialises in the LS motor and has spent a crapload in development on what works best. Not only that but i know many people that have had their motor built by him and they cant recommend him enough. Im not sure exactly what he will recommend when ive got the cash and im actually ready to get the work done, he may recommend some of the stuff that you mentioned and you are right i will ask to bore out the cylinders and go oversized pistons (he would probably do that anyway). At the end of the day i just want a reliable and quiet engine that makes good torque across the rev range and will not slap when its cold or chew out camshafts every 100k. Do you have any other suggestions on who to ask about getting the motor rebuilt in Sydney?
