- Apr 15, 2006
- 22,632
- 20,521
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
So even the rockers 2.25, heads, cam for 2.25, what type of combination/characteristics power wise and streetability do they make ?
Many people previously used to argue no performance cams to be run with anything above 1.8. But this does not seem to be the case, when asking many different cam makers. At the end of they day there can be issues, but it seems Mace may be addressing them in the heads they may be coming out with/testing etc ???
i beleive the highlift cam + 1.8 rockers belief comes from the fact that when you combine high ratio rockers with a cam that has a lot of lift you run into problems with the valve stem seals. machining valve guides and using the corect springs/retainers (to prevent coil bind) would allow much greater valve lift
some numbers,
VNs1 6.909mm or 0.272" (lobe lift) x1.6 (rocker ratio)= .435" valve lift, x1.8 = .490" or x1.9 = .517" or with 2.25 = .612" valve lift
VNs2 6.43mm In. /6.48mm Ex. or .253"/.255" x1.6(rocker ratio) = .405"/.408" or x1.8 = .455"/.459" or x1.9 = .480"/.485" or x1.95 = .493"/.497" or x 1.98 = .501"/.505" or x2.25 = .569"/.573" valve lift.
VS 6.56mm/6.48mm or .258"/.255" In./Ex. x1.65 = .426"/.420 or x1.8 = .464"/.459 or x1.9 = .490"/.485" or x1.95 = .503"/.497 or x1.98 = .511"/.505" or x2.25 = .580"/.574" valve lift.
popular cam figures (so you can calculate your total valve lift with chosen rocker ratio),
wade 992a , .295" lobe lift
wade 1114a, .308" lobe lift
from what i've been told, you run into issues with stock heads at approx .520"- .540" valve lift (depending who you listen too ), so you can see that even with 1.8(buick) or 1.98 (ecotec) ratio rockers there is plenty more lift available before you run into any issues maybe Steve can confirm?
lobe lift values curtisy of gregories automotive manuals
