Ve 2010 sports wagon
Vegimite
67
Vernor
2010 ve commodore sports wagon
Hi all I am left scratching my head have had two mechanics look at my ve engine light on code 1028 not reaching running temp thermostat sensor replaced all has been checked and according to them the thermostat is working car does not use water or over heat mechanic said when engine light on car idles rough when engine light off car runs fine ,has anyone had this issue.ps could it be computer related thanks
Fu Manchu
WA.
P1028? Was there a letter prefix before it?
There is a thermostat (which requires gearbox removal to replace) and there is a coolant temp sensor. Very cheap and easy to replace.
Fu Manchu
WA.
If the car is not reaching running temp, the coolant sensor could be faulty.
The thermostat could be stuck open.
Vegimite
67
Vernor
Yes coolant sensor replaced both mechanics say thermostat is fine,car is reaching running temp code is p0128 thanks
VTS5
TechJunkie
Sth.East\Melb
VE OMEGA 3.6L Dual Fuel
Try third or second hand CTS,(New means,never been used,doesn't mean working),
Make sure cooling fan isn't running as soon as the engine starts.
Make sure proper mixture of red coolant in the system.
If all fails, make sure thermostat not STUCK open..
Vegimite
67
Vernor
Thank you
krusing
Melbourne, Bayside
Make sure there is Thermostat in it!
if it's a V6, I would say the TS is cooked, being where its located,
Replace that first, as that will be the cheaper option.
Vegimite
67
Vernor
Coolant temperature sensor has been replaced engine light disappeared for a few days but back on everything checked by mechanic light is off again we will see what happens thanks
krusing
Melbourne, Bayside
The other thing to check, is the TS plug, as it may have a damaged terminal or similar,
I have read that a couple had weeped out of the top of the TS and had corroded one of the pins/terminals, so that was causing a resistance and triggering the MIL.
  • Like
Reactions: Lex
