PIR4TE
Banned
- Mar 15, 2011
- 2,747
- 74
- 0
- Location
- AWOL with Ari
- Black Pearl
Yes, cuts KR so maybe smooth out your flatspot (in your engine).
As the OP said this is an L77 flex-fuel car so the stock pump should be fine, from memory they even have an E85 badge on the back from factory, so they'd have a higher flow pump than older models. Also if it was the fuel pump I doubt it would only have problems at idle, when there is the least load on the pump.
I have a similar issue with my L98, it shakes at idle and has a slight miss, only when hot, mine is stock apart from the exhaust and K&N filter at the moment. Lots of varied opinions as to what it could be. Some say coils, some say leads (connections seem fine), some say plugs (car has only done 40,000 so I doubt it), and one suggested oil from the K&N may have gotten onto the MAF sensor, which does kind of make sense, but surely it would clear itself away by now (problem has been occurring for over 6 months), and surely it wouldn't be intermittent.
Anyway will be watching this thread with interest!
I'll be interested to see how the colder plugs affect it, I actually had a lead pop off last night which made it shake far worse and barely idle at all, so I'm hoping that a new set of leads might make a difference to it.
Hopefully there not expensive. One ve lead. Acdelco is $75 and one coil is $145 from holden. A set genuine coils from the us is around about
$300 for a set of 8 genuine acdelco.
I can't seem to source the Leads , I think they are the same as the ls7 corvette motor. Would be great to source them some how..
Your car is the same age as mine and I have driven 140+k, I doubt it is the coils. I would just replace the plugs first of all.
Whoa! Why so high?! Mine idles at 540
