Skylarking
- Feb 3, 2018
- 10,114
- 10,562
- 113
- Age
- 123
- Location
- Downunder
- Commodore Motorsport Edition
There is an VF/WN Accessory Install Manual available in this post which may be worth downloading and reading.
Within this document, it is outlined how to do the "steering wheel package installation", presumably to add shift paddles to a wheel that doesn't have them.
What's of possible interest is the note to use tape to ensure the column electrical assembly (clock spring) remains in the top position. Also there is mention of connector colours - black to left side and to connect the spade connectors to the horn. There is also many mentions to ensure the wires are clipped correctly. Finally there is also a requirement to perform a BMC configuration and setup (though i'd expect this is to activate the paddles).
So read the doc, recheck all connections, pins, wiring cable corretly clipped in and retained.
It could be that cable crush may be an issue if the wiring was not correctly retained. Such cable crush may cause wiring shorts and be the basis of your problems. So if all else fails, buzz out the connector for continuity and check for shorts using a multimeter (obviously remove the little loom from the wheel).
Also look at the underside of the clock spring and that it is sitting correctly on the shaft, the cables routed and plugged in correctly.
Failing that, time to visit Holden Service Department and get them to check for fault codes and BMC programing...
Good luck and let us know how it pans out.
