- Apr 15, 2006
- 22,691
- 20,721
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
I'm gonna leave this here
Well the stock shocking steel rocker with friction tip is 8.2 grams and the ultralite roller tip I have as shown above is 7.8 grams.
The max spring pressure is 400 pounds, which is fine, you know for street legal sub nitrous sort of stuff!
The engine builder who recommended these services more than a dozen LS3 engines to race spec every couple of weeks.
Like I said, more speed, better lubrication, stronger, safer, less friction, less noise.
At least do the springs and pushrods at same time mate, you know you want to!
Having the rockers replaced today, just wondering if the engine oil is replaced during the work. Car has done 5700km mostly country driving and just wondering if it would be wise to have the oil changed while being serviced.
Sounds good. I'm very interested.I should say for the benefit of most people who didn’t know what a rocker arm was before this recall, that switching up to a lighter roller rocker arm vs stock will give you minimum 20 horsepower, cooler running and less fuel consumption from the frictional benefit alone with stock tune. Greater potential to support tuning.
There are no downsides just a great opportunity if you want a set-and-forget way to ensure operational longevity and add efficiency.
Versus money spent on headers and exhaust or CAI, swapping rockers enables a genuine bolt-on power increase to the stock tune.
Apart from changing to flex fuel, the next simplest way to add significant volumetric flow is to up-spec the rocker arms to increase valve lift. To accomodate the change you need better valve springs and shorter pushrods (shot peened, nitrided beehives and chromemoly rods are best).
This uprated upper valvetrain works with the LS3 cam and hollow intake valve to safely increase the rpm, so with literally dropping in springs and rods with the rocker swap you will see minimum 25 kw, possibly much more with FBO and a tune.
All reversible, personally recommend after 200,000 miles with this simple upgrade.
Chi-co-ree Auto Cat! Cast for sure (and a bit wonky going by that pic), weird that they are often called pressed steel. But however manufactured, they are heavy, cumbersome, prone to stress failure, badly mounted for NVH and... the needle bearings are cageless.Are you sure the stock ones are pressed steel? I'm no machinist or metallurgist, but these look cast to me.
Thanks Motormouse. See my edited post re weight please.Chi-co-ree Auto Cat! Cast for sure (and a bit wonky going by that pic), weird that they are often called pressed steel. But however manufactured, they are heavy, cumbersome, prone to stress failure, badly mounted for NVH and... the needle bearings are cageless.
Very interesting. Thanks.I'm gonna leave this here
This is what I settled on, there are other combos for sure.Sounds good. I'm very interested.
Can you post up the brand etc of the rockers, springs and pushrods please.
Also, ballpark cost of the parts. Always a factor unfortunately.
I'll be getting my stock rockers replaced, as I want a full set of good ones to keep. But, will upgrade to full roller rockers, springs and pushrods when I get the cam installed. I'd rather go with something proven, like yours, rather than rely on the workshops advice and supplier bias.
I actually resent that I pay to get this crock of crap show as part of my Motor Trend video subscription, cheap LOLs after a few drinks watching the half-arsed backyard bullshit spewing forth from most of them.Very interesting. Thanks.
So, while not an LS3, the comparison proved that the stock rocker (pressed steel non needle roller trunion), made more power than all the standard ratio non oem rockers. The only one that made more power was a higher ration 1.6:1. Even then, it was only able to do this due to other upgrades to stock, including heads with a greater cfm capacity than stock.
This attests to other stuff I've read re stock LS3 rockers (cast, with capped needle roller bearings), ergo the stockies make more power than same ration roller rockers. They may also add to longevity (i.e. less wear over time)and or reliability (i.e. less prone to causing other valve train component failure) of other parts e.g. cam lobes, lifters, push rods, springs, valve tips, faces and seats, as they are lighter and have less interia? Sometimes upgrading just one component, even if better than stock, can add to the risk of premature wear or sudden failure of other components. Particularly at high revs.
As, I said in my other posts, I'm interested in upgrading to the right higher ratio roller rockers, springs etc. But, only with a cam install. I'm not convinced of any tangible benefits over stock, with the same ratio and other stock components. The opposite in fact, i.e I think the cons outweigh the pros.
I'm happy to be proven wrong in my assessment, based on limited past experience, and current research.
Thoughts?
Thoughts?
