ToastMalone
- Jul 17, 2023
- 19
- 7
- 3
- Location
- ↖ Latrobe Valley
- ↖ VZ SV6
To take things further you need a skilled diagnostic tech. Auto Sparkies “generally” (plenty of good ones too) are a bit off the mark with diagnostic skills and equipment. It quite a specialised field and one in its own right.
Without any diagnostic skills or equipment as I’ve shown in the previously linked videos, you’ll be parts swapping to solve it until the whole car has been changed.
I would seek a mobile diagnostic tech.
Still no answers on the fuel relay or continuity from the pump to the relay.
If the pump works but no pressure, you have a Robles with either the pump, the install of the pump (internal leak) or a leak (external).
Yeah the auto elec confirmed the pump wiring was all good and working as intended
Was over it and ended up picking up a cheap second hand engine and putting that in, Car does crank for extended period of time before starting which i think is because the computer thinks its -40 degrees outside so its running VERRRY rich,
the thermo fan is also on all the time when the car starts and even with the key out the thermo fan stays on for a few minutes before turning off. Blowing ALOT of smoke (The exhaust system does have the cats hollowed out from the previous owner)
with a cheapie 2.5" catback (stock headers) - could the exhaust really cause that much smoke?
My engine was 10H7C - This one was a 10H7A (read on multiple different threads that this should be fine?)
The engine itself is very healthy
