nyteshyft
- Jun 23, 2013
- 30
- 2
- 8
- Age
- 36
- Location
- Melbourne
- 2012 VE Series II Commodore Sportswagon
My 2012 Series 2 VE Sportswagon won't start. It makes a constant clicking sound which I presume is the starter motor. I bought the car second hand with 80,000km about a year ago. It has been serviced regularly, it's now got 138,000km's on the odo.
The weird thing about this is, I serviced the car myself (I work in a panel shop, so have all the necessary equipment, ie. hoist, tools, etc.) yesterday. The car was overdue for a service by about 6,000kms. I changed the oil, oil filter and air filter. The spark plugs were changed last service so I didn't bother doing those but I did buy them, I'll do them at 145,000km. Now, I dumped only 2.5 litres of oil out of it, it needs 6.5, so I put that in it. I know they chew through oil and being 6,000km's overdue for a service I figured this was why it only had 2.5 litres in it. I then drove the car from my work to home, which is a 50min drive, it performed perfectly fine, no issues.
Later that afternoon my mrs went to drop off one of the kids to a birthday party about 20 min away. She rang me 10 minutes in to her trip saying that the car was making a rattling sound, I told her not to worry about it as I thought it was just the plastic cover on the engine that I must have not put back on properly.
On my mrs drive back home she rang me saying that the car had "locked up" while going 80kmph for a brief second, as if she had planted her foot on the brakes, she then said that the Stability Control turned itself off immediately after that. She was only about 10 minutes from home so I told her to just take it easy and get it here. She rang me again 5 minutes later saying that the car was displaying "Reduced Speed" on the dash, and was only going about 30kms an hour with her foot to the floor, it was also blowing out plumes of white smoke from the exhaust, the car stalled while she was on the phone to me and wouldn't start again. I drove down there and tried to get it to start but it was as if it had a flat battery, ie. starter just clicking but not turning over. So I went back home and got a jump pack and some jumper leads. I tried jumping it first with a Prado, same result, just clicking and not turning over but it was clearly draining power from the Prado. I then tried the jump pack and same thing, won't turn over.
I've got a 600CCA battery that I bought 2 years ago for my previous vehicle, I'm trickle charging it overnight. Tomorrow after work I'm going to switch batteries to see if that does anything. If I remember I'll borrow the ODBII scanner from work and see if there are any error codes. I've checked the relays in the fuse box under the bonnet and the fuses on the terminal in the boot and they all look fine. I don't know how old the battery in it is, it looks rather new but it also looks original, so it could be 5 years old. I checked the oil and it's full and clean, not milky. All fluid levels are where they're supposed to be. Tomorrow when I change the battery I'll check the jump terminals to make sure they're tight as well as the earth on the alternator.
I don't understand how it was driving perfectly for me for 50min, sits parked for an hour then dies 30min in to a drive. I presume the white smoke coming from the exhaust is excess oil burning off? Maybe I overfilled it a bit? When I was filling it with oil, some of it spilled, I wiped up what I could see but is it possible that some oil ended up on some sort of electrical component, a switch or solenoid, causing it to short?
Does anyone have any ideas as to what's wrong or have possible solutions for me to try tomorrow in addition to what I've stated above?
Thanks in advance!
Thanks in advance!
