Dart77
Donating Member
- Dec 15, 2011
- 135
- 77
- 28
- Location
- Perth
- VK wagon, S1 VE wagon SSV8
I was wondering if any V8 auto owners (6L80 trans) have found any dramas with their auto after having a transmission flush done? Have seen a few YT videos and heard of transmission places being reluctant to do the full flush (which involves pressure and full fluid replacement) because of the risk of foreign matter being pushed into areas where it shouldn't be.
I have been recommended as getting one because the car I just bought had never had an auto service done in 200,000+ km. I got a standard service done straight away and asked the shop to see the pan and fluid before they dumped it and it was horrible, as you'd expect. And the magnets had thick coats of powdered metal on them too.
My plan was to do three auto servicings within a few hundred kms and hoped that doing this would get the fluid pretty clean - because just one service will not get the oil out of the converter.
Saying this plan to the next auto transmission place, (which happens to be an Ultra Tune here in Perth), the workshop manager said that was not a good way to do it and if I was worried about the old trans fluid staying in it, then I should opt for a full flush, but keep the pan on because it's already just had a new filter installed and pan cleaned out etc from the last service. He said doing this will use about 15 litres of ATF and isn't overly cheap at $550. Then again, 15 litres of Dex 4 synthetic would not be cheap.
I mentioned my worries about what I'd heard with pressure flushing but he said it would be all ok because it's just had the pan dropped and a new filter installed, so there shouldn't be any foreign stuff floating around.
BTW, he told me something I didn't know - a dry 6L80 transmission takes over 12 litres of ATF. A lot more than I expected. When you do a standard service, you are only changing about 5.7 litres - the rest stays all through the guts, valve body and converter. So maybe a flush is exactly what it needs.
Anyway, was just wondering if anyone here had had any bad experiences after this process, or heard of any? Thanks.
