VFSV6FORME
- Mar 9, 2016
- 2,603
- 1,273
- 113
- Age
- 74
- Location
- Brisbane
- WN Caprice V 6.0L, VE Anniversity V6 Series 1
I had the same but what I did I purchased a collection of different types the ones that had no plastic in the middle of the spades and pick the one that I can bend because out of the four 3 was different in there construction.Yeah mine looks similar. Had two extra layers of heat shrink on mine which I’ve cut off but still can’t fit it in that orientation. The hard plastic part where the wire enters the fuse tap is a touch long. Can’t bend the wire to make it fit. Might got to jaycar and try find another fuse tap and chop mine off and connect a new one. The one I’m using was supplied and connected when I purchased the Bi modal controller.
..Otherwise I’ll try find another fuse to use but I’m sure you guys had already tried that.
As you can see I have the Bi Modal Control module on top of the battery with velpro and have another peice of velpro holding the cable down
