shane_3800
- Aug 13, 2011
- 4,223
- 1,798
- 113
- Age
- 35
- Location
- places
- vr commo
Or drill out the one you have. @Fu Manchu has a great thread on it.
The only way to be sure oil is "used up" or at the end of it's service life is to have it tested. Colour alone is not a guide.
Something @shane_3800 might be able to answer, how many of the modern engines you service have engine oil heat exchangers that use the engine coolant?
The reason I bring this up is because oil temperature is critical to the proper functioning of the engine but also the oil, too hot or too cold is not good for oil. Too much heat kills the oil from a lubrication point of view, not enough heat and the oil can't burn off contaminants that accumulate in the crank case and you get into sludge issues. Oil temperature needs to be just right (like baby bears porridge). A oil/coolant heat exchanger helps to get oil up to temp faster and also helps to keep it at the proper operating temp but unfortunately this is not something Holden/GM considered for our engines (except the 3800 V6 cars that went to Middle East).
Increasing oil volume is great for extended service life (more oil, more capacity to carry contaminants before it reaches saturation) but if you don't get that oil up to full operating temp what you actually get is.....sludge.
Mom or dad doing the school run in the morning and a quick trip to the supermarket isn't great for getting that engine oil up to temp, if you read many owners manuals you'll note that they say that type of use is considered hard use and you should half your oil service interval.
Something I've not considered, but turbo cars are probably good for heating oil reasonably quickly. Running engine oil through the turbo would be a great way to ensure it heats through quickly....
Engine oil sludge issues....fit a turbo
Yea nearly every car these days runs a oil cooler.
