Car wont start
Jordan_13
30
New Zealand
VF
batteru is fubar
if you test when clicking, probably only 6v
Thanks for the feedback will b getting a new battery tomorrow and see if it starts hopefully that's the problem and not the starter motor
Banjo79
VF SS Sportwagon
I've consulted with the Oracle. It's your fuel pump!
  • Like
Reactions: Lex
lout
60
Langwarrin Victoria
lout
60
Langwarrin Victoria
if the battery has failed as bad as i suspect
i would not be jump starting it
if the battery has gone open circuit
when engine starts you may have severe voltage spikes
if it was just a flat battery, you would jump start same way
but remember, the alternator is not meant to charge a dead flat battery
and an alternator could set you back several hundred dollars
  • Like
Reactions: Lex
lout
60
Langwarrin Victoria
11.4v static is definitely battery
100% , no maybe about it
