Nugggy
- Jul 19, 2018
- 6
- 5
- 3
- Age
- 38
- Location
- Old Bar, NSW
- 2013 VE Commodore series 2 SV6
Hi, I needed to replace the engine in my VE as the old one carked it!
Ringing around, I found that Heaps of people have different ideas on what is right and what works/doesn't work..
I needed an LFX engine and found one for a very reasonable price. Only problem was that it came off a VF (but still the same LFX engine code)
After a few more calls, some people said flatly VF engine won't fit in VE.. They're not compatible etc..
But.. A few wreckers had said that they do indeed fit, but we just need to change the sump to make it fit.
The VF engine was selling for approximately 1/3 the price of a VE engine and only has 16,500kms on it.
So.. I bought the engine. My mechanic took the sump off my VE and put it on the VF engine. Used the wiring harness from my VE and whattya know, It FITS!
got everything bolted on and ready to start.. It winds over but no start!
My first thought was maybe the VE ECU isn't compatible with the VF engine?
I called Taree Holden, who advised that it won't work because it the ecu is VIN linked..
My mechanic then called Holden and was advised that the ECU is only linked to the BCM, not the engine.
Does anyone know if there is anything else that needs to be done to it that could possibly be stopping it from running?
My mechanic is going to get an auto electrician to have a look at it. I just thought maybe someone might be able to help on here..
