NVRAM 11p tuning discussion thread.
someguy360
The Shed
Various
Managed to get out for a good 4-5 hours over the weekend for some tuning.
WOT is perfect at around 12.5-12.7 across the entire rev range so it's ready for this weekends event.
However I'm having a little trouble with light acceleration (Say 5-15% throttle) where the AFR spikes up to 16-17 for about a second then drops back to a healther light load AFR of around 13.5 and will happily lean cruise at light throttle at 14.5-15 it's just light load acceleration that seems to be the problem.
Nothing I do to the VE tables around those MAP readings seem to be making any difference.
It doesn't seem to be impacted by the AE changes I made the other day as I put them back to standard for a test and it made no change.
On a side note I must say I'm super impressed with the 4503 at WOT, this is the first time I've ever really leaned on it hard and it just laid patch through most of first gear....oops
Deuce
Super Stock
'94 VR SS V8
After watching a Steve Morris video the other day, I've been working on map smoothing. Mostly around the lower areas (blue/green). So far the AFR gauge fluctuates less when driving.
Excuse the raindrops on my laptop screen. I just loaded this one into the car
More smoothing later on as more runs and more data comes.
Deuce
Super Stock
'94 VR SS V8
Oh, also worked out that you can click on graph points and drag them up or down to smooth the map.
So much easier than looking at rows/columns of numbers searching for spikes/dips.
someguy360
The Shed
Various
oh wow thats a game changer, thats so much easier
Immortality
Staff member
Sth Auck, NZ
Gosh, I thought everyone knew that :eek:
someguy360
The Shed
Various
@Deuce If it's not super secret IP etc would you mind if I grab a screenshot of what your spark advance table looks like for the 4502?
Deuce
Super Stock
'94 VR SS V8
Yeap, I'll send that through a little later on.
Keep in mind I've got alloy heads which should take more advance than you, although I don't think I am maxed out yet.
Can you return the favor with some coolant offset and idle settings, I'll message you later.
  • Like
Reactions: Lex
someguy360
The Shed
Various
of course, hit me up with whatever you need :)
Deuce
Super Stock
'94 VR SS V8
After more VE map work over the last few weeks, I've decided that I should leave it and then work on WOT VE AFR at the track.
Although the last few days it seemed a fraction rich through the normal around town low rpm light load stuff, so took 1 VE out of about 14 cells, and then today I am recalibrating my gauge sensor because it's probably been a year since my last re-cal.
Then might try and turn all decel enleanment off and run over most of the map again one day.
