I'm definitely not a mechanic or a YouTube mechanic but how does it idol onces it's warmed up?Can anyone explain why my car does this when sitting for 2 days it also does this when parked over night but not as bad. It does not have a cam upgrade either
Idles fine after about 5 seconds or soCan anyone explain why my car does this when sitting for 2 days it also does this when parked over night but not as bad. It does not have a cam upgrade either
I only use Caltex 98 as it is tuned but it started 3 months from new then went away after Holden swapped out the injectors as they failed but it seemed to not do it after that now 30000ks later it has started again but Holden tells me it didn’t start rough for them so they letting it sit for 2 days to try againWhat fuel are you using? My L77 is harder to start after a day than yours seems to be. But I am using E85 from United. It starts easily on 98 and also on the Caltex Flex fuel (when they had it) but I think that was less than 85% ethanol. It also starts easily after less than a day.
AHH! I thought mine had lifter problems, went to holden this morning for them to listen to it, and they said its normal other than it might have an air leak or belt may needs tighten.. L77 problems! I feel on the whole there a good engine otherwise, nothing is without its flaws.I only use Caltex 98 as it is tuned but it started 3 months from new then went away after Holden swapped out the injectors as they failed but it seemed to not do it after that now 30000ks later it has started again but Holden tells me it didn’t start rough for them so they letting it sit for 2 days to try again
Yeah the L77 is a tappy motor. But with mine doesn’t explain why it went away for a year and a half and then starting issue came backAHH! I thought mine had lifter problems, went to holden this morning for them to listen to it, and they said its normal other than it might have an air leak or belt may needs tighten.. L77 problems! I feel on the whole there a good engine otherwise, nothing is without its flaws.
Makes sense but mine is tuned for 98 only also it started 3 months from new until Holden swapped injectors lasted year and a half and 30000ks and now starting issue is backMy L77 had similar starting issues when using 98 but never has a problem running on 95.
There is a theory that 98 fuel contains a % of ethanol to increase the RON and that % confuses the flex fuel sensor into sending more fuel to the motor than is needed (the engine needs more fuel when using E85 than traditional fuels) until it works out it isn't actually seeing E85.
