robgm
- Jun 7, 2009
- 83
- 24
- 8
- Location
- Melbourne
- VZ Acclaim 2005
I've done it..I've successfully replaced/rebuilt the front struts using KYB (i did the rears last month). When i took the originals out the shocks had gone....i pushed them down and they stayed down. Also the top mounts were slightly collapsed, the bearings seemed okay. So top mounts weren't as bad as i thought but i did change them. So i guess the failed shocks were not pushing up against the top mounts, and those mounts slightly worn, hence the gap. I didn't have new bump stops so used the old ones......the old ones sort of deteriorating but still stop dirt getting in. The only issue now is that the KYB screws that stick into engine bay are too big for the original monroe plastic caps. Does anyone know how i can cover those ugly bolts? Photos attached. I also replaced the sway bar rods because i noticed those bushing rubbers had split. Tip: I'm on a slope so i only jacked up one side onto axle stand....so to get the sway bar rod off i had to use the jack to jack up the rotor enough to loosen the rod. Since the sway bar was giving tension due to uneven car position....i guess if both sides were on the same height stands, then this wouldn't be a problem. Thanks to this forum for the multiple procedures, and the haynes manual (especially for torque settings). I'll do a youtube soon....to go with the many many YouTube about this....hope i can add some value.... next job is replacing prop shaft centre bearing.....need to find a decent vice (don't think my stanley quick release will cut it)...
