micko33
http://www.capa.com.au/holden_electronics.htm just bought the one right at the bottom of the list for ve. Its the only one. After market.and able to handle a e85 pump. 120$
Hi! I’ve got a VE SS Sedan with now power to the fuel pump, do you know much about them! CheersYes, I had Fuel Pump issues, as per link,
major fault is the Loom to the Fuel Pump
Your welcome to PM me if you like, I wont go into the logistics in this thread, then I will give you my phone number, and you can call me to discuss what I had to do.
Hope this helps
https://forums.justcommodores.com.a...ol-unit-reversing-sensor-control-unit.274561/
please conact me mate same issue here VE SSV ute:Yes, I had Fuel Pump issues, as per link,
Hope this helps
Possible Electrical Issue - car turns over but wont fire - new fuel pump was installed recently Fuel pump relay possibly, has been bypassed as error codes for car been evident Car was running being able to hear fuel pump, hardwire done via fusebox via pin 30 & 87 of fuel pump relay and now won't start Diagnostic tool required to confirm error codes as a starting point to getting the car running again - list of codes to be provided to me upon completion of task so troubleshooting process can begin Preferred Mechanical Experience on LS Engines
Sorted. Fuse in fuel control moduleI can give you a call,
PM your phone #, and best approx time to call.
And will try and answer your questions.
Not sure my answers may help,
But I will give it a crack !
