[VS] 1996 Ute Accuator Removal and Replacment.
Andy
Donating Member
Muswellbrook NSW
VS Commodore Ute
The Story: My Accuator (Spelling) in the passanger door has gone recently. I have attached a picture of what i see when i look at the base of the unit in the door.
My Problem: The darn cable wont budge from the unit, its STUCK !
No amount of pulling, poking and prodding will move it. From the looks of things its the stock GM part that the car came with. I have attached a picture of my new one feat. my ugly head.
The new one has a computer chip in the hole where the cable is ment to go. Am i missing something here ?
Reaper
Tells it like it is.
RG Z71 Colorado, 120 Prado , VDJ200, Vantage
My opinion is that you need to change your actuator model to something like her:
Reaper
Drawnnite
Obviously Unsensible
2000 Vs Ute
another option, if it doesnt have a clip to unclip.
find another actuator loom thing. cut, solder/crimp and heatshrink together.
eventually you will give up on getting the actuator to work.
i have literally pulled the door apart more times then ive had hot dinners to find out why it wont work.
all connections are fine, everything works. sometimes it has a bad day.
then it comes back to working again.
eventually you just go stuff it. and use the keys in the actual door =P
