The biggest tyre they can fit is 235/70/R16 with two inches of lift.
That comparison is between the biggest diameter possible (19” or 18”) on GTO/sedan/Crewman front strut and the biggest size the Adventra guys can fit (the vehicle has to be lifted to clear body on full lock)
How ever, remember the Crewman already has a one tonne load capacity in the back. Factory tyre size is more than adequate to handle the weight. Stock 16” or 17” wheels
The car will look a bit odd with giant Hindenburgs on there with no lift.
Once you lower the Crewman you won’t have that one tonne load capacity. Put weight in a lowered crewman and you’ll start sweating that the drive shaft is rubbing through the fuel tank. You are not going to find a spare tank over there.
