woooo
- Jan 13, 2017
- 503
- 173
- 43
- Location
- Australia
- Multiple
hi everyone. I have read quite a few posts in search function about brembo brakes. But I'm still a little confused as to what would actually be required to change all of my factory SSV brakes on the VF2 to upgraded Brembo front and rear calipers and also the same size brake rotors (but in slotted and drilled) format.
I was hoping to go AP racing 6 piston front and 4 piston rears but I think I'll try and fit the brembos 4 piston front and rear under my factory SSV wheels for now as they appear to fit fine in other threads.
So my question is; how vital is a brake booster upgrade? Will the factory master cylinder and booster be ok for brembos? What's the difference between the SSV and SSVR brake master?
What size front and rear rotors are the SSVR brembos sitting on under those 19" SSVR alloys? I want to get slotted and drilled rotors same size as the factory SSVR rotors. Will this give better cooling on the rotors and is it ok to put the Brembo calipers on this type of rotor?
Can I then place the Brembo rotors onto the calipers front and rear without modification to anything? Do they sit right in and connect to the factory brake lines? If so I might even change those lines out for braided ADR approved lines if any are available online.
Lastly where do people buy their SSVR Brembo calipers from and what's a good price? I see them on eBay new for $2000 (front and rear) calipers and brake pads only.
I think from reading threads I will have to go with DBA rotors as everyone seems to like them. And what's a good price for a slotted and drilled DBA rotor?
