Footwell lighting
Redline16
MY16 VFII SSV Redline Manual
Front Door trims puddle lamps:
92282206 (led lamp) x 2
92282208 (bezel led) x 2
Also i was mistaken, the door trim puddle lamp loom is part of the door loom, not a separate loom, so didn't get part no's as I'm not going to change the door looms.
Ah makes sense. So the led lamp part numbers are different from the door trim to the footwell lamp? I thought they would be the same
3rspecB
VF2 SSv Redline, White Manual Sedan
Yep they are different. The ones in the bottom of the door trims are bigger from the pics I've seen. The footwell ones are tiny.
Redline16
No worries. Thanks for the help mate
Skylarking
123
Downunder
Commodore Motorsport Edition
I should have gone into the garage and looked at the puddle lamps - My bad :rolleyes:
Had a look at my MSE and how the puddle and footwell lamps are ment to work but the user manual is next to useless.
The only lamp that comes on is the one in the bottom of the door side mirrors. The lamps on the bottom of the door and the footwell lamps stay off whatever i try.
Looked within the config menu and all seems OK re lighting so how the heck am i suposed to get them to work? Or do i have a fault?
chrisp
Melbourne Victoria
VF2 MY16 SS Redline Sportwagon
Maybe they only work when it is dark (i.e. May be they use the light sensor)?
Redline16
Does roof lighting come on?
Skylarking
123
Downunder
Yeah, thought of that so dropped a heavy dark cloth on the dashboard sensor but got no luck with footwell lights.
Skylarking
123
Downunder
Bingo, give the man a cigar :)
No dome (roof) light came on so i pressed the dome lamp switch and then they all worked as expected :p So, i then i briefly looked at the owners manual and there was no mention that the dome lamp is hooked into the footwell and puddle lamps at which point i didn't feel like it was all my fault :rolleyes:
Thanks again @dans_vz and to all others who made comemnts ;)
426Cuda
SUBLIME!
Wagga Wagga
VF Redline Sedan - A6 Spitfire MSE...
No dome (roof) light came on so i pressed the dome lamp switch and then they all worked as they should :p So i then i beriefly looked at the owners manual and there was no mention that the dome lamp is hooked into the footwell and puddle lamps at which point i didn't feel like it was all my fault :rolleyes:
Don't feel too bad. I phaffed around for a while too, until I thought about it being on the interior light circuit. Duh!
Anthony121
VF SSV Redline MY17 & VF Director
I thought that would of been obvious? I know the VE used the light sensor during the day and the dome lamps would not illuminate. VF is totally different electrical architecture.
