MattSAU2XR8
- Jan 23, 2018
- 197
- 103
- 43
- Age
- 51
- Location
- Caloundra
- VE SS Auto 2007
Does feel sort of pre-emptive, or at least keeping up in real time - eg. accelerating through a corner at say 80 km/h with the 'sport' mode selected I can feel a tiny bit of yaw as mentioned above, and its not like it has a second or so of understeer before this happens. Probably not that hard to build it this way since body computer would just have to look for clues such as throttle opening, steering angle, how low a gear, and so on. And likely probably only spends 5 minutes per day sending significant power rearwards so clutch packs should last OK. Agree about the GM pox in general, although to avoid it one would need to find something else as new and quick for the same price :-( I'm figuring to enjoy it while it's under warranty and watch how other people who do higher mileages go before deciding whether to keep it after that. That said I'm pretty sure I read somewhere that the entire twinster drive system including it's own computer is supplied by GKN - same as an Aisan auto trans having its own computer. GKN seem to be based in the UK for better or worse. But have been using this sytem in the Range Rover Evoke since 2014. Here's a nice and not to boasty article about how it works, which notes the 'sport' setting actually changing how much drive goes to outside rear wheel...
https://practicalmotoring.com.au/car-advice/2018-holden-commodore-vxr-technical-details-explained/
And customer feedback on Range Rover Evokes which have the GKN system. One customer DID have a diff problem, not explained in detail, but it seems a Range Rover is not a very reliable car...
https://www.productreview.com.au/listings/2011-2012-range-rover-evoque
