Jason Kennerly
- Aug 9, 2017
- 3
- 0
- 1
- Age
- 48
- Location
- Buffalo,NY USA
- 2015 Chevy SS M6
Wow, if you can get it working I’m definitely ready to swap the unit in my Chevy SS.
The wiring loom required would be a bit of a **** storm. It can be made to be plug and play, but instead of having just a single radio box to do everything, its split into to parts:
1) The HMI which does all the visual displays
2) The Receiver which does all the audio
The connectors are available brand new which means a harness could be made. I wouldnt really want to have to put them together so it could be a DIY job for people to make their own (I just dont have the time!!!)
Next, is mounting. Obviously the units are not designed for the VFs and thus will not have the required mounting points. It may be a trial/error scenario to see what works and what doesnt. The HMI is fairly slim and can fit anywhere, but the receiver is a bit more bulky so will have to work out where it can slot into nicely, which then also means wiring length for a harness needs to be considered.
I wouldn't recommend anyone holding their breath on this though. Anyone thats spoken to me before knows theres always multiple things happening at any one time.
Thanks for the idea but unfortunately not much help in this circumstance. Theres no major expenses in regards to all this. The only thing is the time required for R&D which is the part I am almost always very limited on.I'm down to start up a GoFundMe or some sort of pool if it helps, @TazzI ?
Go man, go!A bit of a thinking out loud comment here...
I had the communication wire from the mylink screen and radio box disconnected from one another, and realized that the buttons do not work with this disconnected.
If thats the case, all commands are sent over the communication line.. which means they can be easily manipulated
Will be double checking later today as it was extremely late last night when testing, but this might be easier then first anticipated.
Unfortunately it appears I do need to reverse engineer the faceplate controls for both the Mylink and the HMI2.5s to maintain those buttons working. Originally I thought I had found something where it was sending the data over the comms line but appears not to be the case.Any update on this. Over here in the states interested. Also any information on possible HMI 3.0 module?
