Glaze
If anyone has experienced this before need some advice, car randomly overheated quite fast and then heater stopped working. 04 VY V6 auto
After letting it cool I probably only filled about max 1L of coolant in the radiator (expansion was dry). Didn’t see any leaks or obvious signs
On the way home temp gauge dropped once below half when accelerating close to 100 then sat normal at 1/2. later on topped up more maybe few hundred mL and bled through thermostat, seemed fine afterward.
Around last year Sept I replaced LIM gaskets (genuine) and water pump (gates), 2 years ago replaced genuine thermostat and a used factory rad and new cap + hoses.
There’s a bit of white smoke from exhaust at times (at operating temp). Car never overheated after LIM gasket repair.
Not sure if thermostat has given out or LIM gaskets failing or head gasket failing? Is there a pressure tester adapter to suit V6 radiators if so where can I buy? Maybe cracked heads? Car has about 408xxx kms
Might test to see if exhaust gas in coolant as well but if anyone experienced similar advice is much appreciated cheers
