What happens if you hold the button up?
I thought all cars must have an emergency brake but can't remember which ADR relates to it.
A quick google didnt find much (other than ADR now mandates automat emergency braking on new cars) but i did find the following*
Emergency brakes, including parking brakes intended to provide emergency braking such as those on vehicles, which do not have split system service brakes or are not subject to ADR31, or ADR35 must be capable of either:
- stopping the vehicle on a dry smooth surface free from loose material, within the distance specified in Table 2
- achieving the deceleration rate specified in Table 2
It seems emergency brakes, other than on trucks and big trailers, are no longer needed because we have redundancy built into the main brakes via split system.
The VF commodore has a split system master cylinder which has two independant hydraulic circuits but they both go to the ABS which is a single pount of failure? The ABS does all sorts of trickery to manage things like the done by the old mechanical proportioning valve (now an ABS software function called Electronic Brake Force Differential, EBD) .
So where is the redundancy that is required so we no longer need emergency brakes? After all, a single failure of the ABS control system and you loose all front/rear brake pressure proportioning even though you have a split hydraulic circuit (that goes to a common ABS module>).
Obviously these ABS system have been working for years without noticable issues but it wouldn't surprise me that the basicas is predicated on only complience testing for a single fault mode and/or the diagnostics system checks everything on vehicle start and warns the driver if there is an anlmoly.
Don't know the ins and outs but i've always liked the security/idea of a hand brake i could pull on should the main brakes not work... And been in a car when the driver has had to do just that (and it had a split braking circuit as well)...
Go figure, regulation?
I haven't looked at the VF owners manual to see what they say on the matter.
https://www.vicroads.vic.gov.au/-/media/files/documents/safety-and-road-rules/vsi26.ashx (results in a download of a Vicroads PDF).
