Skylarking
- Feb 3, 2018
- 10,120
- 10,575
- 113
- Age
- 123
- Location
- Downunder
- Commodore Motorsport Edition
Everything within the vehicle is fused, whether it’s via the 60A? fusible links located at the positive battery terminal, or the main fuses at the rear fuse box or some other blade type fuse located in one of the fuse boxes.Hi,
The heavy 12V cable to the starter is NOT fused. It goes straight to
the starter from the battery.
So a starter motor fault shouldn't blow the main 60A fuse even if there was a
short in the starter when it spun.
I would disconnect the thin wire to the starter solenoid as this would get
its current indirectly via the main fuse.
If the fuse then doesn't blow then the problem is in the starter solenoid.
Cheers.
Fuses exist to protect the vehicle from burning to the ground. So to say the main starter cable isn’t fused is wrong, it is...
Also, the wire gauge within a vehicle varies depending on the circuit one looks at while the fuse associated with that circuit will be sized to protect it’s components and wiring. As such, a wiring diagram is the best thing to have when chasing wiring faults, especially factory wiring diagrams and the associated loom diagrams and connector pinouts. Always replace a fuse with that specified by the manufacturer and nothing else...
Being that the starter control wiring is not a heavy current circuit and normal gauge wiring is used for that circuit, it will melt before a 60A fuse blows!
So I doubt it’s the starter control wiring that is the issue. But it’s been many many years since I’ve looked into the starter wiring though I doubt that’s the faulty part.
Best approach is for OP to look at a VT wiring diagram which should clarify what wires are associated with what function and which fuse will blow when a fault exists.
Still, your suggestion of connection and disconnection of wiring is a good fault finding method when wiring diagrams are lacking (or when previous owner has modded the wiring into some spaghetti abstract or the factory system)...
