Ok, you will need to do this......
New L98 Camshaft P/N 12625439
New 8 x Standard valve lifters P/N 12576400 leave/reuse the other 8 non DOD lifters from L77 engine.
New 4x Standard lifter buckets P/N 12595365-(the DOD lifter buckets are different). Are the old L98 ones still ok? If they are use them. If it was me i'd go new, but was thinking save a few bucks.
All gaskets & bolts required for cam and lifter R & R
Re-use......(from L98),
Valley cover
Intake manifold,(with ALL the hardware from it), injectors, throttle body etc. (dont swap any parts between the two manifolds)
NOTE: The 8 valley cover O-Ring seals MUST BE LEFT IN PLACE (must be installed). Do NOT remove
them. Install them with the L98 valley cover.
Some people reuse gaskets, but if it was me I would be getting all new ones.
Of course also keep all the valve train gear in order and all that ****, so they go back into the same places if it's getting reused.
Good luck mate. Let us know how she goes.
DONT, swap anything else over from the L98 to the L77 doner engine other than what I posted.
