This.just get a major service done and stop worrying.
@panhead - The tyres are inflated correctly, I did check this when the thought popped in my head every so often. As for the fuel I only ever put 20 litres or so in it at a time as I was atleast awear that fuel does go off. The K's it has done were mainly out of guilt having it sit there doing nothing so I dont think the tyres have flat spots.
I’m not sure what I would have done if it had an electric handbrake.
Rossimo’s comment about the AC is a good one, as the seals in the compressor can go very quickly without use and the compressor can leak or go bang when you turn it on. It an unnecessary expense that a little between time maintenance can avoid.
No it should be right if it was well drainedI think you would have been swimming! Glad it was a good outcome
The AC is working fine thankfully.
I changed the oil today, it was as black as night . Also changed the filter which also looked very dirty.
Would it be worth giving it another oil change in a 1000ks or so?
Thanks
Thanks
Thanks
OK I'll leave the oil change for a bit.
Coolant is next.
How hard is the brake fluid flush? Seen Youtube vids looks manageable. Haven't done one before, any tips? Getting to the bleed valve looks much easier if I remove the wheel(s).
You could get yourself a turkey baster or some other syringe tool to suck out the fluid from the master cylinder. Then top up with new fluid then use the bleed valves on each wheel. Always make sure you have eboeno fluid in the master cylinder.
If you're doing by yourself, make sure you also have enough fluid in the bottle or container you use for the bleeding so you don't suck air back into the system.
