GXP25
Can anyone advise on nolathene strut mounts vs rubber? I'm leaning towards stock rubber mounts.
I'd go with the SuperPro Polyelast (durability of polyurethane but softness of rubber; lifetime warranty): https://www.g8board.com/threads/best-rubber-strut-mounts.257178/#post-3420641
If installing Koni rear shocks just check the lower spring mount measurement to the original.
I had this problem with my Koni's. The spring mount point on the Koni shock is different to that of the original shocks. I was running SSL all around with original shocks and it was level but when I changed to the Koni's had to go to a SL in the rear to keep it level.
Correct. The mount sits lower than OEM. You'll need Koni's sleeves to correct this: https://www.g8board.com/threads/nee...n-performance-suspension.265194/#post-3645433
