GXP25
Whatever it left the factory with! Ashamed to say I don't know much more than that
Documentation I've got just says "HSV Performance Suspension"
Do you mind measuring the hub-to-guard?
Aren't Super Pro bushes made of Nolathane?Nolathane will be harsher than rubber.
Super Pro would be a compromise between the two.
This isn't necessarily true, and depends on the Koni product. You can only get the Reds to fit the aforementioned Volvo, for example, so the Bilsteins actually are 4x better.Bilstein is not 4 times better than Koni so why pay 4 times more.
It's a different car with totally different suspension design, but with my old Volvo you pick-and-choose which bushes for which you use rubber & which to use ... I think it's polyurethane (unsure exactly - but Nolathane is a brand-name for whatever -thane I'm thinking of ). If you carte-blanche replace everything with Nolathane it becomes too harsh, resulting in loss of traction on bumpy roads; the rubber is needed to absorb some of the impact.
Yep. They're fitted up and I'm absolutely wrapped! One issue is that the front springs have only lowered the car about 5-10mm. The back has gone down by 25-30mm. They are meant to be SL front and rear. I do note the front springs don't have SL at the end of the part number, whereas the rears do. I'm sorting that little issue out with the eBay seller. He claims they are the right springs.
The FSD's provide a beautifully compliant ride. Yet, the rebound has a precision about it. Squirt the go peddle and it try's to squat, Momentarily. But then the FSD's harden up, very quickly. Turn into a corner or bend with ease, and it glides through the apex. Conversely, hit the apex hard, break or just turn in hard and they tighten up immediately. The turn it is precise, great feedback through the wheel too. Swing the wheel side to side trying to unsettle the car just sees it weave back and forth with very little body roll. It just instils a confidence that had been lost as the OEM shocks lost their ability to dampen the movement of the bulk of the VF on it's chassis. I couldn't be happier. The ride is better. A lot better. Yet the handling and turn in is streets ahead. I'm sure there are firmer shocks. But for me, and as an every day driver, it really is the best of both worlds from my perspective. Even on a track day, I'd be surprise if these would give away much to far firmer shocks. But, on the street, they really come into their own. Supple and compliant, Calais like, but instantly firm and precise when required. I'm a convert to the FSD's for sure. I can't wait to get back in for another spin! I'm really looking forward to a long drive on the weekend to put it through it's paces along with the new brakes.
As for the OEM's? The front's were cut up, so I can't comment. But the rears can be fully compressed with one hand. A full minute later and they only extend about 5cm out of the housing. They are rooted and probably have been for a good couple of years.
Thanks, had no idea these were available. I'll check it out.
I don't know about that ... SuperPro is a brand of suspension components, it's not (AFAIK at least) the name of a particular type/formulation of plastic.Superpro and Nolathane are brand names.
... SuperPro is a brand of suspension components,.....
Like how Whiteline is a brand of suspension components.
I am pretty sure that SuperPro parts that are plastic use Nolathane plastic; at least, they were when I bought my bits.
Sorry, I thought you meant they were brand names of competing product; whereas SuperPro is to Nolathane sorta what Porsche is to Michelin.Correct. I never said anything about a name of plastic.
Not really of interest to you, I suspect, they're in a 1980 Volvo.Do tell.
