How do the air risers work, Auto underload keeps a similar height?
@abuch47 as you’ve likely read the accessory installation manual I linked to in post #8, where it describes Holden’s air suspension in a pictorial form, you should realise that there is no ‘auto’ feature
Holden’s system is a dumb but reliable good ‘ol manual system. You simply inject air into the shocks via the rear mounted Schroder valve when you attach a trailer. Usually one does this at the nearest petrol station as they don’t like old fashion hand pumps
You then let air out via the rear mounted Schroder valve when you uncouple your trailer at home
It’s easy peasy but if you want to get all technical, simply use a tyre pressure gauge when pumping the system up or letting the air out and stay within the pressures as mentioned by
@gohrdrgomad.
If you’re talking of some other automated self leveling system, well it must have as minimum a level sensor on the rear or the car, an air tank and tank pressure sensor, a compressor, a dryer, a few air control valves that let air from the tank into the air shocks and from the air shocks to atmosphere. You also need air lines connecting the compressor, tank, valves and shocks and a controller to manage the lot. This is not what Holden sells as part of their air shock accessory.
