2007 Holden VE SV6 LY7 poor idling
WitiTune
New Zealand
E3 Senator
No i havnt checked tge oil pressure, Its only on start up, when warms up the rpm wont fluctuate. But the law mawer sound is present when i accelerate.
Never mess around with oil pressure, always check actual pressure before replacing the sensor. Not to be rude, but all the other stuff you have posted about with exhaust, o2s, inlet etc should of been left alone until you looked at the cause of the oil pressure code.
Mon-aro
Australia NSW Southern Highlands
VF Wagon, VF ute
Rookies always stuff up unfortunately. Hopefully it wont be something serious
WitiTune
New Zealand
E3 Senator
Yeah hopefully not, id be looking at oil pressure,if your pressure is ok replace the sensor, then check timing related stuff, they can do some really funny things when the vct gears or oil control valves for the gears go, but it is more likely a failed chain than those 2. All of the above I have seen fail without fault codes for them also
Mon-aro
VF Wagon, VF ute
You could be right! When i did the ecu and bcm reprogramming i read something timing chains diagnostic change etc... i will attach a photo.
WitiTune
New Zealand
E3 Senator
Thats just an updated calibration, allows a bit more tolerance in the chain wear before it triggers a fault.
You have access to TLC tho so your way ahead of a lot of people. Are you using tech2win for diagnostics?
Mon-aro
VF Wagon, VF ute
No, For diagnostics I use my trusted Autel MS906BT.
I Use tech 2 and MDI 2 for programming only.
Is there any way i can find for sure its the timing chains? I would rather to be timing chains so i can get over done with.
WitiTune
New Zealand
E3 Senator
Hahaha no beginner I know has an MDI 2
In regards to checking the chains we circle back to checking the oil pressure, the 3 chains all use an oil fed tensioner, if you have low oil pressure the chains will not tension properly, will make noise and can be damaged
Mon-aro
VF Wagon, VF ute
Timing chains are quite as, infact quiter than my other vehicle ( which i just have replaced the timing chains for ) What buzzeling me is why the car sounds like a lawn mower and cold it feels like its going to lose power but when warms up it sattles? And when i accelerate it feels weak? The reason i removed the plenum i thought there is a vacuum leak somewhere.
WitiTune
New Zealand
E3 Senator
Can still be stretched and out of time without a rattle.
Have you checked the misfire counter in live data on the autel to see if any specific cylinders are dropping out?
Mon-aro
VF Wagon, VF ute
I did check no misfire at all in any of the cylinders. Youve got me thinking now I think i should just do the chains, ive got few kits sitting around.
