2007 Holden VE SV6 LY7 poor idling
WitiTune
New Zealand
E3 Senator
Dont fire the parts cannon off its an expensive game that.
Check what sort of g/s the air flow meter is registering, maybe give it a clean if it has a k&n filter as the oil can contaminate it
Check advance/retard of each cam in the scanner see if anything stands out, I know i can see that using my Autel Ultra so pretty sure the 906 should
Mon-aro
Australia NSW Southern Highlands
VF Wagon, VF ute
Hi guys so the vacuum leak is fixed, Oil Pressure Sensor replaced, no warning lights apart from the stability control off ( no fault codes though )
When i start the car on cold the RPM still fluctuate around 500 and the car smokes ( fuel smell ) and after a minute or so the RPM settles just above 500 mark and the car runs fine? Any idea please?
