Ve Brembo 4piston on VF
SnowDoggyDogg
2ltr? = Only milk & juice
Goldie
Gen F GTS
14mm bolt for the Chev/Caddy calipers listed above.
42
VF Calais V v6 S1
thank you.
Is it hard to establish a redirect service with Australia post? As the 6 pot they send to Australia but the 4 pot they don't :)
SnowDoggyDogg
Goldie
Gen F GTS
Nah the shopmate service from Aus Post is pretty flawless.
RED LION
SA
VFII Redline
Yep thanks to SnowDoggyDogg I went through Aus post. Worked very well. Also 20% discount on shipping on your first order.
Getting the paint off them tomorrow, ready for painting on Sunday.
3rspecB
VF2 SSv Redline, White Manual Sedan
@ Red Lion, keep in mind that the front camaro calipers, the brake hose attaches at the top of the caliper and for the OE Holden front brembo calipers, the brake hose attaches at the bottom refer pic. When you fit make sure your brake hose isn't rubbing on anything..
RED LION
SA
VFII Redline
Thanks mate. Hopefully the mechanic does this on Tuesday. I'm sill paranoid about needing the longer bolts. But brakesdirct swears I don't need any.
KING46Calais V
2017 VFII Calais V 6.2L Sed
VE Brembos have 12mm bolts, VF have 14mm bolts on the front. You can fit them but you have to drill out and re tap the
caliper.
Retap the caliper?
Is there threads in the caliper.
I thought the only threads were the end of the bolt to the knuckle.
Are the holes in the caliper 14mm?
Ron Burgundy
NSW
VF II SS
Sooo are you still 12 ?
KING46Calais V
I'm in the process of buy some new brake lines for my VFII
I thought all VF were the same. But apparently not.
Got this response from a supplier
"Hi, VF2 has different inner mating surface in the fittings VS VF1."
Anyone heard of this or know what they are talking about.?
