VE SS - Replaced post o2 sensor - engine light is still on
elmazri
2008 Holden VE SS-V
I have a VE SS and engine light came on with a P2271 bank1 sensor 2, I replaced the O2 sensor on the driver side and cleared the engine code.
Engine code came back on 2 days later with the same code.
Could it be the catalytic converter?
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Try the same sensor on the passenger side.
vr304
Auckland, New Zealand
2007 ssv manual
Probably wouldn’t hurt to change them all if you can afford it they are a service item supposed to be replaced 5 yearly
Fu Manchu
WA.
I've had plenty of issues similar when using non genuine O2 sensors.
syked
Donating Member
2011 WM Caprice
Can you read live data of the O2 sensors?
The pre-cat O2 sensors should be jumping between high and low voltage constantly and the post-cat O2 sensors should be steady high voltage. Check at idle and 2000rpm .
